Help me with designing patch antenna edge feeding condition
v_vishal
Hi all,
I have proble to desing the patch antenna edge feeding condition is that feed element is at the edge and microstrip radiator is at the it is Square patch.
so i want some starting step and basic equation for the transmission line model
patch antenna
hi vishal
First design the antenna for width and length and take size of antenna L * L.
for finding the feed point
1. draw equivalent circuit for the antenna for TLM
2. find the characteristic impedance of transmission line.
3.find point x where you feed the element by radiation resistance.
4. find the width of feed element.
if you have further query then write on my email so i send some basic tutorial on it it you want...!
    v_vishal
patch antenna
you can go through the book microstrip antenna design handbook and microstrip antenna handbook for the design the antenna by the trasmission line theory.
    v_vishal
patch antenna
https://emtalk.com/mwt_mpa.htm
* W: 41.08 mm
* L: 41.08 mm
* lqw: 24.05 mm
* wqw: 0.72 mm
* l50: 15.00 mm
* w50: 4.84 mm
go through this site for this parameter and you can find the very good desing on patch antenna
