atmega8 programmer needed
zohaib
Member level 4
PAKISTAN
ponyprog atmega8
hello everyone
i need a complete project on "avr atmega8 programmer" with schematics and software can any one help me.thanks
atmega8 programmer
you can find STK200-300 schematics and other details in the basecamAVR programs help
onlu 1 buffer on nothing else !
is it helps you or you need more ?
atmega8 security bits with ponyprog
i want to make an avr atmega8 programmer can anyone help me with schematic and software .thanks
ponyprog
thanks amiralib can you inform me about the url
atmega8 ponyprog
this one is the easiest and the cheapest to build. Resistors are 220 ohm. Use ponyprog to program.
http://www.lancos.com/
    zohaib
    zohaib
ponyprog compatible con atmega8
thanx for your quick response
these links are very helping. can schematic in arabi website work with ponyprog?
atmega8 configuration and security bit
no only the last 2 links are for ponyprog
not arabic it is persian ;)
if its useful for you please push the Help me button
    zohaib
atmega8 security and configuration bits
thanx amiralib
i have another question,posted as vb help can you help me regarding this question and also i want to ask you where to go after 8051 avr or pic
atmega8 no response
zohaib said:
thanx amiralib
go after what? for learning or for the exampls or for the working or ....:D
ponyprog.pdf
I sugest you to learn AVR and then you can work in it
you can write your programs in C or Basic or Pascal or ...... (C is better) and you can use all of the abilities of AVR.
its my idea
    zohaib
kmitl atmega8 programmer
it is very simple and 100% works
try it with pony prog
easiest atmega8 programmer
this one also! (stk200 compatible)
some one knows how to program the AVR fuses in ponyprog?
atmega8 програматор
in pony prog
after selecting the device
Command>Security and configuration bits
or for shotr press Ctrl+S
