Problem in installing Office 07
pd
Full Member level 1
India
office.en-us dwtrig20.exe
Hi during installing Office 07 I am facing the following error.It worked for me earlier...but now it is not working.:cry:
Setup cannot find office.en-us/dwtrig20.exe...
while installing microsoft office 2007, i got a window:
setup cannot find office.en-us/dwtrig20.exe.when trying to browse the file location , it says invalid location .
Thanks in advance.:D
setup cannot find office.en-us dwtrig20.exe
pd friend take my advice and do not install it, it is so bad version try 2003 it is good!
    V
office.en-us dwtrig20.exe download
questions in your os system, u must solve it.
office.en-us dw20.exe
The file that your installation setup is looking for is the "Doctor Watson" launcher (dwtrig20.exe). From the error message you posted, setup is looking for the file on you installation media in the U.S. English directory "office.en-us".
What all of this means is that your installation media is probably corrupt. If this is a legal copy of Office, you should be able to get a replacement disk from MS at no cost. If you have a friend with a copy of the disk, you can borrow it to complete your installation. You would just use your own registration code.
If this is a pirated copy of Office, corrupt files are common. You're on your own in that case.
setup cannot find office.en-us dw20.exe
house_cat is right. u might have corrupted file.
dwtrig20.exe office
dont install it, use open office
