What is meant by HVT & SVT cells in library?
what does hvt cell stand for
HVT , LVT stands for high threshold and low threshold transistor cells. This is used for leakage power optimization
svt lvt hvt
To elaborate a bit, processes that support multi-Vt have more than one Vt adjustement processing step (Vt adjustment is done by ion implantation into the transistor channel region), so for high-Vt you implant few ions, for standard a bit more, for low - the most ions.
how are hvt transistors made
For timing critical path low Vt cell is better, but at cost of more leakage power.
For non timing critical path High Vt cell is good choice
svt hvt lvt cpk
hvt: low leakage power library. for low power use but low critical timing.
Svt: middle leakage power library. normal use
lvt: big leakage power library. timing critical path used.
What is typical leakage reduction by replacing RVT cells with HVT, for a deep sub-micron process?
Looking at the databooks of a 45nm std cell library, it seems cell leakage power of HVT is almost as 1/2 as of RVT. Even if I replace all cells by HVT, the leakage only get reduced by 1/2. Is that normal?
Re: what does hvt cell stand for
HVT is High threshold voltage. i.e the leakage power is less for High threshold voltage cells. but for SVT cells the leakage power is more and faster too..
Re: how are hvt transistors made
why does lower vt cells have more leakage as compared to higher vt cells ?
