Script to create Verilog top level module
beowulf
Member level 4
Hi all,
This might be the most comon problem/task for ASIC engineers. I need a script that will generate a top level module for 'n' verilog modules (in 'n' files)
Say I have A.v & B.v. The script should generate a ABTop.v such that
module ABTop(
clk
input clk;
input (etc etc)
output (etc etc)
A A_i (
.clk (clk)
B B_i (
.clk (clk)
endmodule
This can be a perl, tcl, shell script...Any pointers will be helpful
Thanks,
B
I think U shud read design file so that u get module name.. this name shud be used for instantiation !!
perl is easy for pattern matching. read all inputs n outputs from design file n u can creat TOP module file..
The logic is not an issue, I just wanted to know if somebody has done this already (its a common problem) so the wheel need not be reinvented.
btw, readers of this post can take a look at a tool called Topweaver (just google topweaver) which is a GUI based top level module creator. Pretty neat, but a script based tool will be nicer.
There was a site called tclforeda.com which supposedly had such tools, but the site doesnt exist anymore...
Thanks,
B
Thanks,
B
Try www.tclforeda.org
Also Emacs with AUTOINST can do what you are looking for.
Ajeetha, CVC
www.noveldv.com
    beowulf
