Pic IR RC5 Encoder required
UroBoros
Advanced Member level 2
Cochin - India
rc5 encoder
hello
I am looking for a IR RC5 encoder in assembler using PIC! . Any suggessions or examples please!!
protocolo ir sony con pic
Hi!
This is the modulation format in attachment. All you have to do is decode it (measure the signal pause duration). Use any IR module receiver (from VCR or other similar).
All best,
Trax
ir encoder with pic micro
hello
Thanks.I have decoded the pause between signals and derived a seperate code for each transmission. But simply cannot recoganise the coding scheme for transmitters available with me.None of them are RC5 or sony .Something else. Some data packages are even mote than 50 bytes long or it seems so to me .Any clarifications
Thank you
sample encoder ir
@Picstudent
Can you tell me what protocol the remotes were using ?
ir remote pic12f629
Picstudent said:
hello
Thank you
if you have the epe mag then you find a nice tool decode the full information rc5 and sirc code, along with starting packet and ending packet plus a comprehensive artical on both protocol and there working metod all stuff based on pic micro
regards
Fragrance
    UroBoros
sony encoder using pic
Hello Picstudent,
Following image is our CR-2I, RC-5 compatible mini remote commander. It has 5 buttons. simulates standart TV remote commander with RC5 coding. It based on PIC12F629 with sleep function.
If you would like to know all technical details (schematics, pcb, asm etc) please let me know your e-mail. I'm going to send you.
Regards.
[/img]
    UroBoros
rc5 encode
@DDS
Please PM me the details too :)
encodeur rc5
Fragrance said:
Picstudent said:
hello
Thank you
regards
Fragrance
Which edition ?
