HOW TO MAKE A CODE THAT INTERFACES PIC16F872 TO A COMM PORT?
kurimaw
16f872 spi
HI..
CAN ANYONE HELP ME HOW TO HAVE A CODE IN SERIAL INTERFACING PIC16F872..
I NEED IT FOR MY PROJECT..
PLSSS... THANKS
pic16f872 spi
What langauge are you using?
    kurimaw
pic16f872
IM USING THE C LANGUAGE..
CAN YOU HELP ME HOW TO GENERATE A CODE..PLSSS.
THANKS..
Added after 2 minutes:
WHERE CAN I DOWNLOAD THAT APPLICATION NOTE AND THE SOURCE CODE??
THANKS.
It is easy, learn RS232 Communication protocol, search the board, you will find lots of related projects.
Btw, check your CAPS LOCK if it is ON, it is very annoying to see all caps post.
    kurimaw
Do yourself a favour and start using CCS C
Re: HOW TO MAKE A CODE THAT INTERFACES PIC16F872 TO A COMM P
pic16f877 is also different with the pic16f877 regarding about the USART..coz in 16f872 theres no usart or a uart....only the SPI and I2C..
pls help me to generate a code for serial interfacing using SPI or I2C..
thanks
CCS C has exmaples for this very purpose !!
If I helped you, click on "Helped me"
i am also doing this project.......it helps me a lot
a simple search at google or eda will give you many results....
As VSM... mentioned CCS will provide you with guideline
alternately check MiKroC and download its manual, go through it and you ll get your answer
