Microcontroller(AVR) info: software, hardware, books
jhanus
Croatia
spipgm
I want to learn how to program AVR(Atmel).
So help me in following areas:
-hardware: I found PonyProg at
https://www.electronics-lab.com/projects/mcu/008/index.html
https://www.electronics-lab.com/projects/mcu/009/index.html
Is this programmer any good, in fact what do you suggest?!, any
better schematic?!
-software: I was thinking AVR Studio 4 for assembler and codevision for C.
What do you suggest?!
What I know and don't:
I know C, C++, soon I will learn assembler, I programmed in Bascom and I don't like it, and I want to avoid it, I also have PG-302 from middle school, now I'm studying electrical engineering at college.
80c51 to pony program
hi
programmer circuits do the job no problem i am using spipgm i found it very easy, also it is available on the net
www.avrfreaks.net ur new homepage!!!!!
for assembly yes avr studio , for c i didnt use it yet
    jhanus
pg302 programmer software download
your choises are ideal and very good
    jhanus
microkontroller avr book
hi,
try this reference book, AVR Microcontroller
regards
    jhanus
spipgm avr
hi
www.avrfreaks.net is a very good site for avr learners
for pony prog its ok
u have to take care of the following
avr studio , codevision, bascom are ur software simulator u try ur codes and see the results. these programs creates hex files
pony prog,spipgm they are the programs that will take ur hex file and put it on the mcu ,each has its own programming circuit that will be connected to the computer( from serial port in case of pony prog,parrelel port for spipgm )
so
"so PonyProg won't have problems with AVR Studio 4 and codevision, they support PonyProg?! "
of course no problem they are seperate ,got it?? :D
    jhanus
hardware hindi verson book
Thanks,
I saw that codevision had it's own module to communicate with programming circuit, that's why I asked, but to code in one and program in another, no problem.
Now I'm off to building.
dafahmi said:
hi,
regards
Thanks, but I can't download it (some kindergarten points), can you link it.
spipgm problem
use WinAVR, you will get a lot of sample codes. www.avrfreaks.net is the forum where you will get help instantly and accurately for AVR. I use BSD programmer. See my programmer
Bibin John
www.bibinjohn.tk
easy avr
Here is the simple and very easy AVR programmer with own software..
Do you have CD of book "Programming and Customizing the AVR Microcontroller". It contains many useful example codes.
Can you upload here?
