The easiest microcontroller to learn about
clairvoyant13
Member level 3
Which microcontroller is the easiest to start with?
easiest microcontroller to program
PICAXE, without any doubts ..
Regards,
IanP
easiest way to program a microcontroller
For me, I suggest to get start with PIC, it has suffecient resources online and many practical project to practice as well..
Start by buying a PIC chip (Say 16F624) and lookfor its programmer online (easy to get) build a programmer as well as simple test circuit with few LEDs and push-buttons at in/out ports pins, you may add some touches like LCD or keypad or whatever..
Then, get some tutorial, and follow up to end (along with practice!).
Of course you have to get the Datasheet as well as some application notes related to the project you aim.. (but the most important is the Datasheet!)
Select the language you use to program with (I suggest to start with Assembly!!)
Make projects, ask for help .. :)
Best Wishes..
Ahmad,
micro controller theary tutorial
Teh easiest mcu to learn is the Parallax's Basic Stamp. Look at www.parallax.com for tutorial and examples.
If you have grabbed all basic technique with BASIC STAMP, you would be "promoted" to mcu such as PIC, 8051, etc.
John
easiest to program microcontroller
Only PIC ...... easiest
easiest microcontroller to use
ATMEL AVR family controllers are very good easy and more suitable for embedded applications.
u can use attiny2313, atmega32 or any other of avr family.
the programmer is so easy just search google for "pony programmer"
Any thing among PICs, AVRs, and PICaxe.. all are cool :)
basicx-24 microcontroller india price
read the datasheet of 16f84
PIC is a RISC device that you can write programs by learning a few instructions this makes it really easy to learn, also 8051 is another easy uC for a beginner.
However, I prefer Motorola uCs, because of it's architecture and reliability and I recommend you to start with Motorola 68HC08...
Regards...
68hc12 microcontroller tutorial
8051 is pretty easy to start with. I recommend that u also get the book by yousaf mazidi on 8051 microcontrollers. Its a great book for beginners.
easy way to program microcontroler
I suggest to learn Atmel AT89C51, it is compatable with 8051
the internet has many example about it
also, it is easy to migrate from Atmel AT89C51 to Atmel AVR for more complex projects.
best regards
Ahmed
picaxe 08 basic picaxe core
hi,
You start either PIC or 8051 both are simple to understand and easy to impliment and also lot's of information on search engines as well as edaboard.
wish you all the best
thanx
68hc12 microcontroller theory and applications
do you have the solution for this text book please
Pack, Daniel J. and Barrett, Steven F., 68HC12 Microcontroller. Theory and applications,
16f624 download
Go for avr if you want to have a general approach as the different avr's donot vary too much..... start from atmega32
picaxe 08m tutorial
I am confused.
Is it true that BASIC is one of the easiest programming languages?
If yes, can someone advice which BASIC dialect should I choose: BASCOM, PICBasic or PICAXE BASIC?
www.rev-ed.co.uk/docs
There are microcontroller modules BasicStamp and BasicX. Hardware is more expensive, but the development environment is free and easy to use.
PIC with CCS compiler is easy to learn too, but the compiler would cost you.
microcontroller easiest
the easiest and most popular core is 8051 ......... hundreds of varients of C51 available and it is good start for the beginers
motorola ucs
Yes, mate ..
BASIC is one of the simples languages, and PICAXE is probably the simplest dialect of all of them ..
Dowload these three manuals on PICAXE, part 2 describes PIC BASIC ..
https://www.rev-ed.co.uk/docs/picaxe_manual1.pdf
https://www.rev-ed.co.uk/docs/picaxe_manual2.pdf
https://www.rev-ed.co.uk/docs/picaxe_manual3.pdf
Software is free (**broken link removed**), you don't need any special programmers (PICAXSE is directly connected to PC's serial port) etc. etc.
I really can't see enything else simpler than that ..
Even if a lot of memnbers may say: 8051, AVR or PIC is very simple, but as far as simplicity is concerned NOTHING can beat PICAXE ..
Regards,
IanP
avr learn 8051
Hi
I have been comfortable with 8051. Maybe I should start looking at PICAXE, after all the above discussion.
