How to build Digital Thermometer using ATmegsa8 and LM335?
Ankster
Newbie level 6
hello ,
I am planningto build Digital Thermometer using ATmegsa8 and LM335.
Can Somebody tell me how should i go about ??
I want to display it on LAMPEX LM16200 (16x1 LCD)
Thanx
Ankur
atmega8 thermometer
Maybe this can help
adc0804 connection
Hi!
I have already done this i am attaching the code may be it will help you. I used the ICC AVR compiler. The connections are
RS------PB4
RW------PB6
E--------PB5
D0------PB0
D1------PB1
D2------PB2
D3------PB3
I have used the internal oscillator at 1MHz and configured the ADC to use internal reference of 2.56 volts. The LM35 is connected to channel 0.
Regards.
thermometer atmega8
thanx waseem
But i am not able to open the file ..
Can u directly send me code to mail mail-account (i hope it is in asm)
or anyway send it to me . just cut , copy and paste
Thanx
Ankster
adc0804 lm35
Hi!
post your email address so that i can send you the code. I cannot understand why you cannot open the file.
It is simply a compressed file. The code that i have been talking about is written in c language.
Regards.
lm335 thermometer
hi
here am attaching you the link for DIGITAL THERMOMETER project based on ATMEGA8.am alsoattaching the ATMEGA8 datasheet for your reference
http://www.tldp.org/linuxfocus/English/February2005/article365.shtml -->
The Atmega8 microcontroller from Atmel has plenty of digital and analog input/output lines. It is the ideal device to develop any kind of measurement equipment.
In this article we see how to interconnect the microcontroller to a linux PC over a physical RS232 interface without the extra MAX232 chip.
Hope this link helps you in completing your project.also am attaching the CIRCUIT DIAGRAM.see it and tell me whether this was helpful for you or not?
regards
john
MODERATOR ACTION: attachment atmega8.pdf removed do not upload files that are freely available at the net post a link like this instead:
http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf
project on digital thermometer
Check this:
The page is on the croatian language but I can help you with translating...
atmega thermometer
hi all,
any sort of translation from any language to english(readable) and viceversa can be done using babelfish.try out this link
http://babelfish.altavista.com
regards
john
atmega 8 thermometer
Most IC digital temp sensors acquire temperature readings through one of their pins. Also, some temperature conductance occurs in the plastic to the core of the IC itself.
You must account for this or you will not display an accurate temperature. I sugest that you go to Texas Instrument's site and read some app notes on this subject. I found them helpful myself.
Regards,
The G Man
lm335 atmega
as lm335 output is 10mv/C so the maximum volt at max temp would only be 1.250 volts for 125 celcius so, first feed the output of lm335 to a buffer (opamp gain=1) and then to a opamp with gain=5/1.25 (to utlize full scale reading) and then to ADC input (internal or external ADC, whichever u choose). I suggest you to use DS18s20 which have same TO-92 package as lm335 but is much simpler to use.
digital thermometer atmega8
Hi Garg,
You forgot that LM335 has an output voltage of typical 2,982v at 25 °C.
For 50 °C the output voltage is 2,982 + 0,250v = 3,232v and not only 0,5v as you supposed.
Try now feeding the opamp buffer with this value (3,232) and then see where the opamp output goes (supposing that VDD rail is far above of +5v)
Thus your opamp gain should be modified a little to use a full scale reading. Don't you think ?
A much elegant approach is to use a common mode voltage of 2,732v for opamp and a gain of 5. Then you have a full scale of 5v for 100 C.
lm35 adc0804
I am looking for digital Thermometer and digital clock project.
would you please help me?
digital thermometer projects
try looking here
lm335 avr
i think i mistakened lm335 with lm35.
digital atmega themometer
dear friends , i feel very happ to let u know that THERE IS NO NEED TO USE OP- AMP WITH LM35 SENSOR. USE IT WITH ACD 0804 AND DIRECTLY APPLY THE OUTCOMMING VOLTAGE TO PIN 6 OF THE ADC0804 IC.
ISNT THIS VERY EXITED..? HAHAHHAAAAAAA......
TEL ME IF I AM WRONG..
atmega168 thermometer
any one have a source code in assmbly for atmel avr and lm35 interfacing
lm335 opamp
hi all
i am doing a project for temperature with lm35 and adc 0804....
i dun know how to connect between 89s51 and adc 0804
by the way...i also din know how to write a program in C langauge which get the data from the lm35 and converts the data into digit and display on the LCD (16X2)
i would appreciate it if u can sd me as a reference
thx
send to me if possible.....tomdotwoo@hotmail.com
thermometer using atmega8
8051 - ADC0804 Connection diagram:
This code is written for Keil C51:
#include <reg52.h>
void outLCD(char c);
pdata unsigned char ADC0804;
unsigned char ReadADC0804(void){
     ADC0804 = 0;   // invoke ADC0804 to start conversion
     while (P3^2) ; // waiting end of conversion
     return ADC0804;
void nain(void){
unsigned char v;
     v = ReadADC0804();
     outLCD((v/100)+0x30); v = v % 100;
     outLCD((v/10 )+0x30); v = v % 10;
     outLCD((v    )+0x30);
    V
atmel thermometer
thx your reply...
your information is very useful!!!
thx.....
Added after 12 minutes:
another question......
am i correct to connect the lcd at 80c51 which from p1.0 to 1.4
and how to wirite and run the program in C to get the output on LCD display...
thx a lot.......
code adc0804 8051 keil
[quote hello waseem i need code for digital thermometer will u send this as u send anker][/quote]
