[Hspice]How to plot derivative or integral value of a curve
pugongying
Member level 3
hspice derivative
I want to simulate the value of gm of a transistor,which is gm=ΔId/ΔVgs,I know how to plot the I-V curve,but how to derivate it?
Also,I want to simulate the kT/C noise of a RC filter,I know how to plot the noise density,but to how integrate it ?
Thanks!
hspice plot
You can derivate it in awaves. Just build a expression in awaves and plot it.
how to plot an integral
Thanks ,but I am using cosmos scope
I can't find the integral or derivative funtions
can anybody help me ?
hspice integral
I also want to know!
plot derivative hspice
Firstly, plot the signal Id, or i(m1)
Secondly, from the graph window, select the plotted signal -- Id, and Press Ctrl-X to cut or Ctrl-C to copy it.
Thirdly, open the calculator with menu "Tools / Waveform Calculator".
Lastly, in the calculator, choose menu "Edit / Paste". Then Click button "deriv" to derivative or "integ" to integrate it. And click toolbox icon "Graph X" to plot the derived signal.
Hope this will solve your problem.
Reactions: gladysh
    pugongying
    gladysh
derivative hspice
Hughes,Thanks very much!
hspice deriv
Another method to get gm of the MOS transistor:
use .probe LX7(M*) or .probe GMO(M*)
You do not need to derviate anything.
how to plotderivative
you can use another tricky way, first generate a delayed VGS(probably by a few ns) and apply this delayed Vgs to another instance of the same cmos device, and then get the corresponding Ids1, then simply use a current controlled voltage source and set approporate coefficient to translate the Ids-Ids1 to certain voltage, the output of this voltage source may reflect the derivation of Ids/Vgs
cscope calculator integrate
Thanks a million. That was also what I was searching. I want to add a few keywords such as cscope and calculator.
