LEFT shift operator for numbers
shiv_emf
Advanced Member level 2
Hii guys... i am confused with left shift operator ...
suppose i left shifting a NUMBER ..will the sign of number changes??
for example ...
suppose for integer type variable ... size of integer is 4bytes tht is 32 bits
system fallows 2's complement representation ... if v shift smalllest negative number ...what will be the result ??
Re: LEFT shift operator
Hi shiv_emf...
In C, if your variable is signed, the signal will be extended, but if thew variable is unsigned, the compiler automatic zero filling. Is this your doubt? i hope i were helpfull
LEFT shift operator
hey thanks for ur reply !!
but
int x;
this statement is signed integer ... if i leftshift it tht is
100000000000000000000000000 (1 in msb and 31 "zero")
wht will be the output ??
it is zero or same number as .. signed bit shud nt be changed
it´s better you force zero initializing. for exemple
int x = 0;
x = x <<31;
the output is x = 0;
if
x = 1;
x = x << 31;
then
x = 0x80000000;
was i clear? its better to initialize your int. if you use unsigned int, its automatcally zero initialized.
    shiv_emf
LEFT shift operator
another one
in case of Negative number !!.... system stores these values in 2's complement
now if u leftshift variable ..... will Signed BIT changes???
i hope i am clear now
Hi shiv_emf, thanks for "Helped". It was a pleasure.
Now, if your variable, signed, is negative and left shift, the signal will be kepted. It´s the same os thats instructions in asm that rotate left keeping the signal. Was i clear?
You need to be careful on this one.
Right shifts are implementation dependent. That means that you need to look up how your compiler treats signed right shift with negative values. It could be either a logical shift (you lose the sign bit and it becomes 0) or arithmetic shift ( sign bit is kept).
All Microsoft compilers use arithmetic shifts.
The easiest way to tell is to write some test code and set an int to a negative value, right shift it one and use the debugger to look at the result.
    shiv_emf
LEFT shift operator
nice one ... thanks for help :)
well i am working on REDHAT linux OS ... using GCC
so i hav to chk it out ..
shiv_emf said:
another one
new operator <<< try it
Verilog 2001 defined >>> and <<< for signed shifting operations.
Amr Ali
