What are the reasons of signal distortion in IC and how to minimize it?
jutek
Full Member level 4
hello
what are the reasons of signal distortion in IC and what are the ways to minimize it?
i mean generally not particular circuit.
regards
signal distortion
sometimes, the nonlinear will cause the distortion.
Re: signal distortion
The power or ground plane is not good. The reference is coupled to distored by other circuits.
Yibin.
    jutek
Hi jutek
signal distortion have several reasons including THD.IMD.Nonlinearity and so on.For examples, the relationship between current and voltage of transistors are not linearity,especially in case of large signal acts,which cause THD. Meanwhile,the common mode voltage,that determine dc opration point, would introduce Nonlinear
errors when set up inappropriate.
that is my little view
    jutek
Hi heartwide,
What does setting up inappropriate mean?
Thanks!
Make signal path linear.
signal distortion
All of the distortion can be related to linearity, although there are many ways to cause the bad linearity.
Fundamentally, it will at least have sth to do with the inherient nonlinear
I-V relations either for CMOS, BJT, GaAs etc. Feedback is a very effective
way to reduce it, recall, for example, source degeneration.
    jutek
mainly non-linearity.solution : feedback,high dc gain ,layout issues,charge injection and many many
