treehugger
Ids remains (nearly) the same, even though the drain voltage is increasing with respect to source. Why? What is the underlying physics?
thanks in advance
Added after 18 minutes:
i need a somewhat detailed explanation.
an answer like "because the drain side is pinched-off" will not count.. since i am looking forward to know "why the pinching-off implies a constant current?"
thanks in advance
