What's the diffrence between Vcc and VDD?
16F676
hi friends,
vdd vcc
Hi
there is not any difference between them in the circuit design.
    16F676
difference between vdd and vcc
It goes back in history, Vcc applies to transistors, Volts collector common, Vdd applies to fets, Volts drain ?. Vee, Volts emitter ?. It's been lost with the passage of time!
what is the difference between vcc and vdd
how about Vpp?
vpp vcc vdd
Programming Pulse voltage. Back when the 2708 EPROM was king, the programming was done with 25V pulses applied to the Vpp pin. The timing requirements on this voltage were rather stringent (and the algorithm complicated), so the next parts, starting with 2716, used a FIXED 25V voltage and the programming pulse was just a TTL signal applied to the PGM pin.
However, the name of the Vpp pin lives on, even though it is now used to only supply a DC voltage. You will find it even on FLASH devices. Applying 12V to this pin (again, DC, not pulses) speeds up the programming of the FLASH (but it is not necessary).
In some microcontrollers, such as FLASH-based PICs, the Vpp is required only to put the part into programming mode, not to actually program the internal FLASH memory. For that there is an internal charge pump. But the name Vpp is still used.
vdd and vcc
I think they are same, you must
understand them in specifical case.
best regards
16F676 said:
hi friends,
    16F676
