Which language is easier and better, Verilog or VHDL?
deh_fuhrer
Full Member level 5
Which one is easier and better to learn.
verilog vs vhdl best language
if you have learned c, i think verilog is easy,
but i think vhdl is good for newer
    deh_fuhrer
verilog vs vhdl
As a student, VHDL may be the language you should learn first.
in company, verilog is more popular (cuz of inertia and c-style syntax)
However, It's very easy to learn other language after you be familiar with
a language.
    deh_fuhrer
Re: Verilog Vs VHDL
verilog is easier to learn
it is closer to C
but u should start by learning VHDL
it is a bit complex but it is more rich and powerful
and if u start by it, u will find that verilog is very easy
    deh_fuhrer
Verilog Vs VHDL
which book is the best to refer to for a beginner in verilog
i know vhdl........but not too fluent
    deh_fuhrer
Re: Verilog Vs VHDL
Hi
Industry is more tied to Verilog.
Haytham
    deh_fuhrer
Re: Verilog Vs VHDL
Verilog HDL: A guide to digital design and synthesis
by Samir Palnitkar
it's great for a beginner
good luck
Salma:)
    deh_fuhrer
Re: Verilog Vs VHDL
Verilog By Moorby is the best.He was part of the team that developed Verilog in Gateway Design Automation.
    deh_fuhrer
Re: Verilog Vs VHDL
Go thru the following links to know which is better for your design either Verilog or Vhdl...
h**p://www.techonline.com/community/tech_topic/21147?print
h**p://www.angelfire.com/in/rajesh52/verilogvhdl.html
Verilog Vs VHDL
i prefer verilog since it requires only very less code for doing a function.
Re: Verilog Vs VHDL
See this first!!!
Re: Verilog Vs VHDL
Any of you guys has a link to the books mentioned or a good tutorial to verilog????
Regards,
Shohdy
Re: Verilog Vs VHDL
Verilog based on C language
VHDL based on Pascal language.
Re: Verilog Vs VHDL
Verilog is easier to learn when compared to VHDL
Verilog Vs VHDL
i think Verilog is easy to learn.
and thd VHDL is goog for describe
