Inputting negative mu and epsilon in HFSS ?
svarun
Full Member level 5
In the warm company of God's most exquisite creati
negative epsilon hfss
Hi all,
Is it possible to input negative epsilon and mu values in HFSS 9.2/10.1 and get the results that show negative refractive index ? or will it just take n=sqrt(abs(epsilon*mu))
svarun
nri_lenses_hfss.pdf
Yes you will see negative refraction. This can be seen here
    svarun
+hfss +k vector
Hi savedadogs,
Yes !. I found that at the interface between media (n=1 and n=-1), the normal component of E and H fields changes directions and the tangential component remains same.
I was wondering whether there is a way to plot the 'k' vector in both the media to show that EM wave bends away from the normal. Is it possible to plot the k vector in HFSS ? Can you throw any light on this ?
svarun
I do not think you can plot the k vector...you can however use the field calculator to plot the phase of the electric field....you will see phase advance in the LH region and phase delay in the RH region.
    svarun
