vsmGuy
Advanced Member level 2
computer powersuply
Can I use the computer ATX PSU to power my electronics circuits ?
I see many using their ATX SMPS as PSUs, but I noticed that the output current is typically in range 1A to 20A. For example +12v is supplied at 10A
Most of the ICs we use have Icc (supply current) in 50mA range, for example, the popular MAX232 has Icc specified at 50mA
So if I were to connect 5v, 1A supply from ATX SMPS to supply MAX232, will it go bad ?
So how can I use the ATX SMPS to power my circuits ? Use a current limiting resistor ??
