Concatenate String in Verilog?
davyzhu
Advanced Member level 1
oriental
verilog concatenation
Hi all,
I want to open a lot of files and read data to reg.
something like
//-----code--------
$readmemh(".\pattern\0.dat",inmem0);
$readmemh(".\pattern\1.dat",inmem1);
$readmemh(".\pattern\49.dat",inmem49);
//-----code end----
I want to use something like strcat() in C to concatenate the string.
So, I can use a loop to replace large block of code above.
Is there any method to do this work in Verilog?
Any suggestions will be appreciated!
Best regards,
Davy
verilog string concatenation
you can try this:
case(i):
0: begin $readmemh("./pattern/mem_0.dat, mem0_reg);end
1:begin $readmemh("./pattern/mem_1.dat,mem1_reg);end
default: begin $display(" Nothing to Open " ); end
endcase
    davyzhu
verilog concatenate string
hi davyzhu,
You can use $swrite to do what you want or use the attach file that I had implement C-like string manipulation function in verilog task.
Sincerely,
Jarod
    davyzhu
verilog concatenate
davyzhu said:
Hi all,
something like
//-----code--------
//-----code end----
Best regards,
Davy
Verilog/SV has $sformat that is pretty close to sprintf in C - guess that's what you need here.
HTH
Ajeetha, CVC
    davyzhu
