Difference of signal divider, power splitter etc.
pit
Full Member level 4
power splitter difference
Hello!
What is the precise difference in these devices:
- signal divider
- signal splitter
- power divider
- power splitter
Up to now I have learned that a signal divider with 3 ports has three resistors (in triangle configuration, in a 50 Ohm system every resistor has 50 Ohm), isolation from each port to any other port is 6 dB.
A power splitter has only two resistors, is that correct?
What about the other two?
CU
power dividers power splitters difference
"Frequently Asked Questions about Power Splitters & Dividers. . ."
Regards,
IanP
    pit
50 ohm signal splitter
I think power divider and power splitter are the same
difference between a power divider and a splitter
Very good, that helped me! Now I know the precise difference of "splitter" and "divider".
Is there also a difference between "power" splitter|divider and "signal" splitter|divider?
CU
Added after 9 minutes:
What just came to my mind: what is the advantage or disadvantage of building a power divider in a star configuration vs. a triangular configuration?
CU
microwave signal splitter
The same as making a T or Pi attenuator.
E.g. Pi attenuators can be used for higher freqs, because of their smaller "length".
    V
spiltter divider difference
So a star configuration refers to a T attenuator, which can be used for lower frequencies.
A trinagular configuration refers to a PI attenuator which can be used for higher frequencies?
CU
3 path resistor divider
With the same chip size: yes
    pit
unterminated power divider
Hello!
Thanks a lot!
But with a triangular configuration I get additional waveform dispersion because the wave can travel on two paths: one path directly over one resistor (50 Ohm), the other over two resistors in series (2x 50 Ohm).
The total inductivity is smaller (2/3) than that of a single resistor in a triangular configuration.
With a star configuration there are always two resistors in series the wave must travel along. As it is a single path only there is no waveform dispersion due to different paths, but the inductivity is doubled (two resistors in series).
Is having a lower inductivity more important than having a single path?
CU
Added after 23 minutes:
What I still don't understand is this sentence in the document:
"Power dividers should not be used in ratio and leveling loop application because a mismatch condition of nominally 3:1 would exist."
If I have a power divider (triangular configuration) with three resistors of 50 Ohm each, and I terminate two of the ports with 50 Ohm, then I can see a load of 50 Ohm on the unterminated port. (BTW: in this configuration the resistor across the two terminated ports doesn't carry any current because there is no voltage difference across it.)
So why is there a 3:1 mismatch condition?
CU
