Matlab, How to get frequency spectrum?
davyzhu
Advanced Member level 1
oriental
matlab spectrum
Hi all,
I am a Matlab newbie :)
How to get frequency spectrum of a vector data? (something like [3 4 2 10 ...])
I heard FFT is the time-frequency fransform. And I tried fft() function in Matlab.
But it return a complex number. Is it stand for both frequency and phase?
Any suggestions will be appreciated!
Best regards,
Davy
matlab frequency spectrum
Hi
Yes, the fft results contain both amplitude and phase information.
To plot only the amplitude try abs( fft( ... ) );
Another useful MATLAB function for psd plotting is pwelch.
frequency spectrum matlab
Hello Circuit_Seller;
In fft() you get fft. But if you want to plot it, you need frequency, that is you must write:
plot( f , fft )
How you can get frequency vector?
matlab frequency plot
Circuit_seller wrote:
If N is the FFT length and Fs is sampling frequency then
f = 0 : Fs / N : ( Fs - 1 ) / N;
I think that your expression isn't true.
Fs / N > ( Fs - 1 ) / N
Can you explain more? How did you take this result?
plot spectrum matlab
Lets try to help:
In order to plot a simple estimation of the spectrum using fft you must pay attention to some details.
Try to increase resolution using zero padding.
Try to avoid spectral leakage, it is easy when you know the spetrum and are just confirming it using fft.
use the command fftshift it takes the center of the signal to origin. eg Yn=abs(fftshift(fft(y,n)))/N where N is the number of points of the signal and n >N is the number of points of the DFT ( n-N is zero padding).
In order to plot the frequency you do:
Having a DFT with n points the vector of frequency is f=[-n/2: (n-1)/2]*Fs/n using this and the fftshift the values in the plot are directly given in Hertz.
I hope have helped
Reactions: ddharty
    davyzhu
    ddharty
frequency plot matlab
Hi
Sorry,
f = 0 : Fs / N : Fs - 1 / N;
matlab plot spectrum
type in matlab command window, the following one by one
help plot
help stem
help polar
furthermore, suppose that Z=complex matrix, then
real(Z) , GIVES U ONLY REAL VALVUES,,,
complex values can nicely be plot in polar graph, by plotting:
abs(Z) against angle(Z)...
i think it will help u..
plot frequency spectrum matlab
Hello;
Circuit_Seller wrote this relation:
Can anyone explain more about this relation? How is the relation resulted?
matlab fft spectrum
Hi
When you perform a FFT with length N, [0 Fs] is divided to N frequency bins.
So to produce frequency bins i wrote that expression.
fourier spectrum matlab
I am uploading 2 PDF files on Fourier Transform / Spectrum calculation and display in Matlab. I used it for the lab of DSP.
You can also use the below function for displaying the frequency spectrum in MATLAB. As "N" the number of points for fft increases the spectrum becomes more accurate to the theoratical values.
Here 'signal' is the data vector for which u want to see the frequency spectrum. 't' is the time vector for which the signal exists , 'ts' is the sampling time , 'N' is the number of fourier transform points.
function[freq,mag]=fouriertransform(signal,t,ts,N);
S=fft(signal,N);
CS=[S(N/2+1:N) S(1:N/2)];
freq=[-N/2+1:N/2]/(N*ts);
mag=abs(CS);
figure;
plot(freq,mag);
fft spectrum matlab
Hi
Well fft gives a complex function.
To plot absolute value and d phase type following
plot(abs(fft))
plot(angle(fft))
u can also refer to help files
frequency spectrum in matlab
Perhaps that tutorial about FFT can help you
Reactions: Riheen and mpython
    V
    mpython
    Riheen
phase spectrum matlab
This is my understanding about DFT. DFT builds the relationship between the samples of signal x(t) and the samples of its FT X(f).
time-domain sampling interval is T, the sample freq is FS=1/T. and freq domain sample interval is f0, so time domain truncation duration is 1/f0=T0, and both sampling number in the t-domain and f-domain are N=T0/T.
so the t-domain data is x(T*n) ,n=[0:N0-1]. data point in t-domain is 0:T:T*(N0-1).
and x(t)'s discrete fourier tranform is fft(T*x(T*n)). and the freq point is 0:f0:FS.
Added after 1 minutes:
matlab spectrum plot
a=abs(fft
b=angle(fft)
plot(a)
plot(angle(b))
matlab fourier spectrum
in MatLab help is good example for fft,
roughly output spectrum in dB is:
20log10(abs(fft(sin(2*pi*fc*tt))))
in this case the amlitude is 2 peak-to-peak that corresponds 10 dBm@50 Ohm for sine signal with amplitude 2Vp-p. MatLab shows power 0dB@fc
Can somebody say how take into account this 50 Ohm output impedance to get proper power?
matlab plot frequency
if you want to plot the frequency and phase response of the vector you have, you can use the function freqz....
spectral plot matlab
select fft box from DSp tool box.
matlab plot frequency spectrum
let s be your signal;
N = NFFT
Fs = sampling freq
y = fft(s,N);
p = abs(y);
f=Fs/N.*(0:(N/2)-1);
plot(f,p(1:N/2));
will give you the power spectrum
spectrum in matlab
davyzhu said:
Hi all,
Best regards,
Davy
hi,
the solution of this problem is that first find the fft then try the command freqz()
that have the arguments fft result,1,1024.
