Take a look at the bottom info bar in this picture, under the description of the function keys;
By selecting a trace with only 1 click while in the route mode, you'll see a description of the trace at the bottom of the view that states " wd: 25, ln: 375, etc
This view is done in thousandths/inch, so wd: 25 = line width of .025 ". You'll also see current ratings for the line plus the actual location of the trace.
