odod
Newbie level 5
jtag 74hc244
I am trying to setup an external power source instead of useing the 5 volt supplied from the computer's LPT port. The pinouts are as follows,
TDI TO PIN 4 ON THE DB25
TCK TO PIN 3 ON THE DB25
GND TO PIN 18-25 ON THE DB25
TMS TO PIN 2 ON THE DB25
TDO TO PIN 13 ON THE DB25
TRST TO PIN 5 ON THE DB25
I want to use a regulated 3.3 volt power source. I created 1 using batteries. My reason is to advoid to high of power from the computer and also eliminate anything that could harm the computors motherboard.
If someone could help that would be great.
I'm trying to reprogram a 29LV8008BTC
You can also email me direct @
od@intersat.cc:
od@intersat.cc:
