Why does my opamp, configured as a buffer, oscillate?
hitlgc
Newbie level 6
why my op amp oscillate?
Hi all,
I designed a folded cascode op amp with a class-AB output stage to drive a large capacitor. When I configure it as a buffer, it oscillates.
I did the .pz analysis, and find out that the frist pole is +16.3369MHz.
What should I do?
Thank you for you help!
Re: why my op amp oscillate?
I don't see any results for ur circuit, but try to check the phase margin of ur OP-AMP, as it may need a sort of compensation
    hitlgc
the phase margin increases at 10MHz, reaches 60 degree at 40MHz, and then fall down.
I add a capacitor between the input and output of the second stage, but it doesn't work.
A schematic diagram of your circuit incl parts values would be helpful. Then we all can take a close look in order to help you.
    hitlgc
I don't know how to display the pictures directly, so I have to upload the files.
I modified the circuit after I obtain this result, the result seems better, but the problem also exists.
Look in THE ART OF ELECTRONICS on pag 242 until 248. In forum has the book for download ... the circuit when you work with a buffer is very nerly of 180º margin, if you add a RC network on output you elimine the internal frequency compesation of aomp. Then aomp osc... you have to create a dominante pole for eliminate this effect.
leomecma
    hitlgc
I think there is some problem with ur circuit regarding phase margin. The phase plot which u have given is not showing dominant pole characteristic rather it is not the actual characteristic which u should get from ur design.u should keep the phase margin more than 60 degree to get the thing stabilize.have u checked ur circuit with out any output stage if yes then tell me what was the gain and phage margin u r getting from there.
    hitlgc
hi all
I modified the compensation capacitor, and now the problem has been saved.
thank you for your help.
can you tell me how can i find this book?
i looked for this book in the forum,but i couldn't find it.
leomecma
    hitlgc
Is the plot of the phase right ?? Does the y-axis represent the phase or the phase margin ??
If it represents the phase, so u have a phase margin about (180 + 60 ), i.e. PM = 240 which is not logic !!!
    hitlgc
For the plot I have given, the phase is not right.
I changed the structure of the class-AB output stage, and modified the compensation capacitor.
Now, it's ok.
