Chinmaye
Full Member level 3
Dear all,
I am trying to find the CMRR of 2 stage diff input and diff output opamp in cadence. To find differential gain, I provide 0.5V to positive input and -0.5V to the negative input. Then I plot (Vo+ - Vo-)/(Vi+ - Vi-) over a range of frequencies to get the plot of differential gain over a range of frequencies. To calculate the common mode gain, I give 1V to both the inputs and plot the magnitude of either Vo+ or Vo-. The calculated common mode gain is not matching with the plotted gain. What mistake am I making here?
