olemp
Full Member level 1
serial.inf
hi!we will sent a byte or stream of bytes to the pc parellel port serially(with pic mcu)...and parallel port should know baud rate(bytes may be in different baud rates) and values of the bytes...
we will use c++ with inport and outport functions(we will access to parallel port directly)...
is it possible to do that process???
what kind of algorithm we should use to read byte or bytes...
what do you suggest........
