padi
Newbie level 3
Hello. I am using a SYH-2R humidity sensor. It is connected to a Raspberry Pi using a MCP3008 ADC.
I successfully connected the sensor and i can get realtime readings, but i have no ideea how con convert those information to relative humidity.
This is the datasheet: **broken link removed**
I will upload a .txt with the values that i get from the sensor.
It is possible to find the RH ? Or i need to buy a calibrated sensor ?
View attachment file.txt
