[Moved]: how to write FINFET code in Hspice????
sainadh
please anyone help me regarding this
Re: how to write FINFET code in Hspice????
Do you need a FINFET model? If so, for which process?
The rest of any code (analysis, test bench) is the same as for a "normal" MOSFET.
thanks for reply
yeah i need FINFET model for any technology model.
please can you send netlist for simple inverter.
I want to design FINFET in HSpice.
i understand that thank you very much
Even though i got one more doubt i.e FINFET is having is more than one gate
in CMOS we use(D,S,G,B) for FINFET like this we have to go(D,S,G1,G2,B) or is there any changes.
... for FINFET like this we have to go(D,S,G1,G2,B) ...
For a simple inverter you can combine G1 & G2 together.
okay thanks
For other circuits like SRAM or any other how to write spice code if we use two gates ???
FINFET is operated by two gates normally. If we connect two gates together it makes any difference than CMOS because it operates on single gate.
Try and find here, especially this one, slides #12 ff.
hii
i undertsand the concept but the problem for me is to write spice code by using two gates of a device.
i wrote code like this
.param g2=0    ***GAte2 of pfet***
.param g4=0    ***Gate2 of nfet***
***assigned zero as the  back gate voltage for both transistors****
inv_1 out vdd vin g2 vdd pfet
inv_2 out gnd vin g4 gnd nfet
Voltage1 vdd gnd  DC 1.0
Voltage2 vin gnd  PULSE(0 1.0 0 1n 1n 25n 75n)
.PRINT TRAN V(vout)
.PRINT TRAN V(vin)
.tran 10n 200n
.end
**error** no definition for 0:vin
it was called by 0:inv_1
this is the error i'm getting
how to get rid of this
Try this:
1. G1 shorted to G2
2. gnd connected to node 0 (necessary)
Hope your FinFET models are pfet and nfet, and their nodes are declared in this order:
D S G1 G2 B
PHP:
* .param g2=0    ***Gate2 of pfet***
* .param g4=0    ***Gate2 of nfet***
*    D   S  G1  G2   B  model
M_1 out vdd vin vin vdd pfet
M_2 out gnd vin vin gnd nfet
Vgnd     gnd  0   DC 0
.PRINT TRAN V(vout)
.PRINT TRAN V(vin)
.tran 10n 200n
.end
great, i tried that it's worked.
i'm getting one more error
**error** model name pmos in the element 0:m_1
is not defined.
I'm using PTM 16nm technology library to simulate the design
** PTM-MG 16nm HSPICE Model Card for HP PFET
** Nominal VDD=0.85V
.model pfet pmos level = 72
+ bulkmod = 1
+lmin    = 1e-008          lmax    = 3e-008
** PTM-MG 16nm HSPICE Model Card for HP NFET
.model nfet nmos level = 72
+ bulkmod = 1
is not defined.
Your pfet model refers to a pmos model level = 72
(and nfet model refers to a nmos model level = 72)
... so you need to
.INCLUDE ...
... these models. If you don't have them already, you'll probably find these modelcards somewhere in the BSIM-CMG, Latest Release section.
Download the .zip file, unzip and search for the modelcards. The same directory also contains sample HSPICE netlists for various analysis setUps (.sp files)
hello
i want simulate FINFET INV
what is netlist for it??
please help me???
*inv fin
*    D   S  G1  G2   B  model
Vgnd     gnd  0   DC 0
.PRINT TRAN V(vout)
.PRINT TRAN V(vin)
.tran 10n 200n
.end
i have a lot error
please help me
hello
1)i want simulate sram finfet but in ptm there are 32nm finfet for subcircuite but i dont want simulate sub circuite what i do??
2) for sram netlist for sizing finfet i must for pulldown transistor 3fin for pull up 1fin and for access 2fin????
thanks
