How to transfer a value of an output from DUT to test bench?
ragulto516
Newbie level 2
Would like to ask how to transfer a value of an output from DUT to test bench?
I have the following code:
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
module my_mod(a, b);
    input a;
    output b;
    assign b = a;
  endmodule
  module my_mod_tst();
    reg x;
    wire y;
    reg z;
    my_mod_tst mmt(x, y);
    initial begin
      x = 1;
      z = y;
      if (z == 1)
        display$("Value of z is %d", z);
    end
  endmodule
But it does not work.
It will help others and probably yourself if you explain what "does not work" means. What happens? What did you expect to happen? Look at the log file carefully.
Reactions: FvM
    FvM
You have not instantiated ur RTL in the first place. Check out the syntax for instantiating...
Yes, apologies, I have instantiated the module incorrectly and here is the rewrite.
  input a;
  output b;
  assign b = a;
endmodule
  reg x;
  wire y;
  reg z;
  my_mod mm(x, y);
  initial begin
    x = 1;
    z = y;
    if (z == 1)
      $display("Value of z is %d", z);
  end
endmodule
But after running it in simulator the test bench variable z becomes equal to 1'bx. Is there a way how to transfer the value from module under test to test bench correctly? Thanks.
The statement z=y and the display statement should be in always blocks and not in the initial block.
This is a simulation race condition. You are writing variable x and reading wire y with no delay in between. The initial block and continuous assignment are two independent processes, and without any delays or wait statements in the initial block, there is no guarantee that the continuous assignment in my_mod will execute in between the write and the read. Different version of Modelsim/Questa produce different results.
Generally, you write to your DUT inputs at one time, and read your DUT outputs at another time.
module my_mod(input a, output b); // preferred way to write your ports
    assign b = a;
 endmodule
    reg x;
    wire y;
    reg z;
    my_mod mmt(x, y);
    initial begin
      x = 1;
      @y // or #1
      z = y;
      if (z == 1)
    end
  endmodule
In most cases, you have a clock and can apply stimulus on a clock edge with a non-blocking assignment, and read the stimulus from the previous clock cycle at the same time
