Robo
Junior Member level 3
sharp gp2y0a21yk
I've just bought the distance sensor, but I'm not sure how to use it. I understand that the closer the sensor is to the wall, the higher the output voltage will be. But what do I do with the output voltage so that I can program my robot to avoid hitting walls? (By the way I'm using board of education with BasicStamp 2 module)
I know somehow I need to use an ADC to obtain the digital signal. But how do I let my board of education to "read" the digital signal?
My initial thought is that I connect the output wire to one of the P0 to P15 ports (let say P0), and I program with BasicStamp with the following pseudocode:
if P0 > 2.5V
turn left
else
continue going forward
However, I don't think my BOE will detect what the output voltage is at P0. Anyone has any idea? Thanks.
if P0 > 2.5V
turn left
else
