dizgah
Member level 5
hi every body i have a problem with this function & dont know reason of it:
i know problem is related with PcdComMF522 function(red sectio) becouse after running this function
outcome wi be status = MI-ERR(indicate error)
but i use PcdComMF522 function in other place and it work very well
thanks any body
lib.h
char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue);
main:
unsigned char mount[4];
status= PcdValue(0xC1,4,mount);
lib.c
// @ Function: debit and prepaid
// @ Parameter Description: dd_mode [IN]: command word
// 0xC0 = debit
// 0xC1 = recharge
// Addr [IN]: wallet address
// PValue [IN]: 4 bytes Increase (decrease) in value, low in the former
// @ Return: the successful return MI_OK
char status;
unsigned int unLen;
unsigned char i,ucComMF522Buf[MAXRLEN];
ucComMF522Buf[0] = dd_mode;
ucComMF522Buf[1] = addr;
CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
[COLOR="#FF0000"] status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
[/COLOR]
if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
{ status = MI_ERR; }
if (status == MI_OK)
for (i=0; i<16; i++)
{ ucComMF522Buf[i] = *(pValue+i); }
CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
unLen = 0;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
if (status != MI_ERR)
{ status = MI_OK; }
ucComMF522Buf[0] = PICC_TRANSFER;
return status;
//@ Function: RC522 and ISO14443 card through communication
//@ Parameter Description: Command [IN]: RC522 command word
//PIn [IN]: data is sent to the card by RC522
//InLenByte [IN]: send data byte length
//POut [OUT]: return data received cards
//* POutLenBit [OUT]: Returns the data bit length
char PcdComMF522(unsigned char Command,
unsigned char *pInData,
unsigned char InLenByte,
unsigned char *pOutData,
unsigned int *pOutLenBit)
char status = MI_ERR;
unsigned char irqEn = 0x00;
unsigned char waitFor = 0x00;
unsigned char lastBits;
unsigned char n;
unsigned int i;
switch (Command)
case PCD_AUTHENT:
irqEn = 0x12;
waitFor = 0x10;
break;
case PCD_TRANSCEIVE:
irqEn = 0x77;
waitFor = 0x30;
break;
default:
break;
WriteRawRC(ComIEnReg,irqEn|0x80);
ClearBitMask(ComIrqReg,0x80);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
WriteRawRC(CommandReg, PCD_IDLE);
for (i=0; i<InLenByte; i++)
WriteRawRC(FIFODataReg, pInData[i]);
WriteRawRC(CommandReg, Command);
if (Command == PCD_TRANSCEIVE) { SetBitMask(BitFramingReg,0x80); }
i = 2000 ; //600;//????????,??M1???????25ms
do
n = ReadRawRC(ComIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitFor));
ClearBitMask(BitFramingReg,0x80);
if (i!=0)
if(!(ReadRawRC(ErrorReg)&0x1B))
status = MI_OK;
if (n & irqEn & 0x01) {status = MI_NOTAGERR;}
n = ReadRawRC(FIFOLevelReg);
lastBits = ReadRawRC(ControlReg) & 0x07;
if (lastBits) { *pOutLenBit = (n-1)*8 + lastBits; }
else { *pOutLenBit = n*8; }
if (n == 0) { n = 1; }
if (n > MAXRLEN){ n = MAXRLEN; }
for (i=0; i<n; i++)
pOutData[i] = ReadRawRC(FIFODataReg);
else
SetBitMask(ControlReg,0x80); // stop timer now
return status;
thanks any body
