Bidirectional motor control without MCU or NE555
jmx66
Member level 5
France
Hi all,
I found this schematic, and i want to know if there's no mistakes...
In fact, motor current is about 2 A ,so what resistors values for TIP122 - TIP31 become TIP122 - ?
It's for a road book, so no MCU, NE555 ...
Thanks a lot.
jm
Thanks a lot for your reply.
For more current if TIP31 replaced by TIP122, resistor values changed?
Thanks a lot.
jm
Thanks a lot.
jm
Yes you can .. But you should have a supply of higher current because Tip31 supports 3A flow and Tip122 supports 5A flow ..
Reactions: jmx66
    jmx66
Thanks a lot.
Don't worry about power supply...
Alternator + bridge output of Yam 500XT: so 60 Watt isn't a problem.
Jm
Aren't some of the base resistors missing.
Reactions: jmx66
    jmx66
Thanks a lot first,
Right for upper transistor, so mistake on this schematic?
For lower 2.2 KOhm and 10 KOhm.
Regards.
jm
