How to compare & verify that two structures are equal in
UroBoros
Advanced Member level 2
Cochin - India
Simple 'C 'doubt!
Hai
How can we compare and verify that two structures are equal in C ,Especially in CCS C .
if(realtime==shedule1[0])
this is giving error. (neumeric expression required)
both are structure variables of same type.
Sorry i am not a 'C' expert !
Picstudent
Simple 'C 'doubt!
Sorry, see question 2.8 in the C FAQ:
https://www.eskimo.com/~scs/C-faq/q2.8.html
If you enjoy living dangerously, and have intimate knowledge of your compiler's memory allocation, then you may be able to use a memory compare function such as memcmp(). But beware of non-portability issues.
As you learn C, you will have many questions. This FAQ is a great resource!
    UroBoros
Simple 'C 'doubt!
Did not check for errors , but should work OK :
typedef struct {
int a;
char b;
float c;
dluble d;
} mystruct;
comparestruct (mystruct *struct1_p, mystruct *struct2_p)
char *p1_p, *p2_p;
int k = sizeof(mystruct);
p1_p = (char *)struct1_p;
p2_p = (char *)struct2_p;
for (;k!=0;k--)
if(*p1_p++ != *p2_p++)
return -1;
return 0;
    UroBoros
