Lathas
In an attempt to create a solid trapezoidal structure, I have created a one rectangle at Z=0 plane and another one at Z=1mm. I used connect surface option to combine the 2 rectangles to form the trapezoidal structure. Then assigned the material as dielectric. In this case, what will be the material inside the structure :dielectric or air?
