viperpaki007
Full Member level 5
I am designing a simple operational amplifier, which should work at 4V supply and have an output voltage swing from 3.7 to 0.5 V. I made the following design. The design is working fine at supply voltage of 1.2 volts. Now i have to make it working for supply voltage to 4V. Considering the breakdown voltage of each transistor is 1V. How can i increase the supply voltage? Do i have to use cascode transistors now? if yes then in which way?
