How to deal with the .zap file?
Ruritania
Member level 5
how to use zap files in ads ?
I've downloaded some file with the suffix of .zap, how can I deal with that?
Thank you.
unarchive zap file
hi Ruritania
.zap files are archive files for A-gilent A D S (Advanced Design System) unless there is some other application uses the same file convention.
You use ADS to un-archive the file, which is archivation of a project you do in ADS. ADS is used in Microwaves.
If you have ADS, then from file-menu choose unarchive project.
"File->Unarchive Project"
