zlotvor
Newbie level 2
Doe's anybody knows what type is this connector and if there is a commercially available replacement for the mating side (the opposite connector or socket) be kind and share yhe knowledge?
This is Metcal STTC soldering tip, what I need is a connector I can use to experiment with the tip without destroying it.
OD: 4.0mm
Pin OD: 0.9-1.1mm (can't measure)
Thanks, Z
OD: 4.0mm
Thanks, Z
