need help on microcontroller and lcd module.....
adbonja2000
Newbie level 1
i have a problem.... and need an opinion, an example or anything information that can help to solve my problem....
my question is how to programme lcd module using microcontroller????
basically i use assembly languange for my project
i use microcontroller motorola MC68HC11E1
lcd module Tranma Alphanumeric dot metrix liquid crystal displays without backlighting, 14 pins, for example....RS stock numbers 184-8538
the lcd data sheet can be found at the www.rsmalaysia.com
this project very important for my final year study....
so plz i beg u all help me!!!!!
[/code]\][/list]
I did NOT look up your LCD , but assumes it is "Hitachi HD44780" compatible , most characterbased LCD displays are.
10 seconds with google reveals this
I will leave the challenge of interfacing to the HC11 up to you.
But it might be a good idea to use "HD44780" as one of the google parameters , it should ensure lots of hits (also for the hw. connection).
Btw: Pay attention to the initialization routine if you choose to tun in 4-bit mode , that is the only pitfall in 4bit vs 8bit mode.
/Bingo
Hmmm.. Are you sure the Lcd name isnt TIANMA ??
Have a look here for HD 44780 info
http://www.myke.com/lcd.htm
http://home.iae.nl/users/pouweha/lcd/lcd.shtml
I did a search on google , for "Tranma lcd" and there was only one hit.
http://www.piergm.com/elettronica/datasheet/Display%20LCD%20'intelligenti'%20alta_grafici/HD44780.pdf "But it seems like the link is not valid"
You should still read the DS and find out if ots a HD44780 compatible controller that is on. (Lots of controllers are 44780 compatible , even though they are named something else".
I would still expect it might be Tianma.
/Bingo
hi adbonja 2000,
i love motorola ic because it is easy to handle even now i go to pic because it is cheaper. what'up buddy. contact me at sabree8@hotmail.com for help if you really need me.
bye
