[SOLVED] Board making sound on power up
rvspr
Newbie level 6
Hi
I have an issue on EVM board.
One board is making sound on power up..
As it is a socketed board,i removed the processor and checked it,there is no sound.but on placing the processor it is making sound..
The board is fine(no short r low resistance in any voltage rails)
Then i isolated a inductor in 5V rail,no sound.The inductor I had isolated is an inductor in buck converter like shown below.
What will be reason/cause for this sound
1.Is the inductor gone bad?
2.any other device in the power rail is causing the problem?
or any other thing that can cause this kind of issues.Kindly Share the ideas to solve this issue.
Rajan
Hi;
Is your coil shielded one?
Sometimes, shielding ferrites have some cracks and glues (connection coil and ferrite) is broken in that case it may cause some "hiss" noise.
Try to replace coil.
Goodluck
Reactions: rvspr
    rvspr
what kind of sound are you talking about? is it a humm? if yes, you might have a faulty inductor.
Reactions: rvspr
    rvspr
How are you powering the board ?
Check if your external supply has a programmable current limit or maybe it isn't powerful enough to drive the required load.
Reactions: rvspr
    rvspr
Hey you guys are right..:)Thanks
The inductor had gone bad...
With that I have some questions
1.What may be the reason for the failure of inductors?
2.With that problematic inductor,i found fast switching of transistor (ie) the freq is ~720Khz instead of 350Khz..Any reason?
3.If the transistor have some problem ,will it cause such effects?
