[SOLVED] An example for an op-amp circuit?
DC177E
Newbie level 6
Hello All,
Wondering if anyone could give me an example Op-amp circuit that would take a -0.5 to 1.5v input and output a voltage between 0-(any voltage under or equal to 5v) for reading with an ADC? (Sorry if it is a really noob-ish question, don't work with op-amps very often :grin:)
Thank you in advance.
you can use a differential amplifier
Apply 0.5v to VR, V1 to gnd and the input to V2.
If all resistors are equal then you will get 0-2v, if you use RF twice the size of R1 then you can get a gain of 2 and 0-4v output.
You can also use a VR of 1v to get some headroom in case the input is <-0.5v and then compensate for this in software
Reactions: DC177E
    DC177E
