[SOLVED] which mode is suitable for LCD interface
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
Dear all I am using ATmega32 with LCD.
I am displaying some messages on intrrupts.
if there is no intrrupt i need to save power.
My question is which mode is better for it
Power down
power save
idle
etc
i work on PIC and 8051
at this time i have LCD code of PIC 18f452 of 16x2 LCD may be it is not help full for you
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
#include<18F452.h>
#use delay(clock = 4000000)
//#use I2C(MASTER, SDA=PIN_B1, SCL=PIN_B0,FAST=400000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#fuses NOWDT,NOPROTECT,NOLVP,XT
#define EN PIN_C7
#define RW PIN_C6
#define RS PIN_C5
unsigned char we[10]= "PIC LCD:";
void delay()
 long i;
for( i=0;i<=6555;i++)
void interface()
 output_b(0x3c);
 output_bit(EN,1);
 output_bit(RS,0);
 output_bit(RW,0);
 delay();
 output_bit(EN,0);
void DISPLAY_CURSOR()
 output_b(0x08);
 output_bit(EN,1);
 output_bit(RS,0);
 output_bit(RW,0);
 delay();
 output_bit(EN,1);
void clear_display()
 output_b(0x01);
 output_bit(EN,1);
 output_bit(RS,0);
 output_bit(RW,0);
 delay();
 output_bit(EN,0);
void blink()
 output_b(0x0f);
 output_bit(EN,1);
 output_bit(RS,0);
 output_bit(RW,0);
 delay();
 output_bit(EN,0);
void home ()
 output_b(0x02);
 output_bit(EN,1);
 output_bit(RS,0);
 output_bit(RW,0);
 delay();
 output_bit(EN,0);
void lcd(unsigned char ch)
 output_b(ch);
 output_bit(RS,1);
 output_bit(RW,0);
 output_bit(EN,1);
 delay();
 output_bit(EN,0);
void main (void)
int i,j,count;
for(i=0;i<3;i++)
      interface();
      delay();
      DISPLAY_CURSOR();
      delay();
      clear_display();
      delay();
      blink();
      delay();
      home ();
      delay();
      for(j=0;j<10;j++)
      lcd(we[j]);
//printf("char=%c",we[j]);
      delay();
      count=count+1;
      if(count==16)
      clear_display();
      count=0;
you can use power down or idle mode, because intrrupts will wake up your circuit.
After displaying complete messages you should enter idle mode intrrupt will wake up, then you perform your required commands and again enter idle mode.
This will be enough I think you can understand what I want to say
I have no idea about power saving mode
but i think that 4bit mode or 8 bit mode approx. same power consumption
i have no more detail about your problem
