Yes, you can use the for and generate statements inside a process...
No you cannot. Generate is meant for conditionally creating/repeatadly creating some logic. You can however use generics inside a process - they are treated as constants, so remember the logic you may generate by using a for loop.
OK...so "generate" can only be used out of process.
What are the constraints about the "loop" statement ? Only in a process ?
