[SOLVED] Need Help with 16f628 internal eeprom
janosandi
Full Member level 4
I need help with internal eeprom of 16f628
i've tried the original write procidure of Microchip's datasheet but it didnt write to eeprom
here is the code i've tried:
                             ;movlw	0x01
			;movwf	EEADR
			;movlw	0x06
			;movwf	EEDATA
			;BSF STATUS, RP0 ; Bank1
			;BCF INTCON, GIE ; Disable INTs.
			;BSF EECON1, WREN ; Enable Write
			;MOVLW 55h ;
			;MOVWF EECON2 ; 55h must be written to EECON2
			;MOVLW 0xAA ; to start write sequence
			;MOVWF EECON2 ; Write AAh
			;BSF EECON1,WR ; Set WR bit begin write
			;BSF INTCON, GIE ; Enable INTs.
When i've tried to write AAh to EECON my assembler writes an error i've write 0xAA instead maybe it's the problem
Your help will be appriciated
You need to be using bank 1 for EEADR & EEDATA.
   movlw    0x01
   movwf    EEADR
   movlw    0x06
   movwf    EEDATA
   MOVLW 55h ;
thx for ur help i will try it asap
is it ok to use 55h first for EECON2 then 0xAA instead of AAh ?
Yes, it's okay, because both are saying that it's in hex. 55h = 0x55, 0xAA = AAh. Same either way you write it.
Hope this helps.
Tahmid.
Thx Cubanflyer it works fine
