varunme
Advanced Member level 3
what may be the reasons prevent the below IR sensor circuit from working ?
https://farm6.static.flickr.com/5267/5594627404_e2ab55647d.jpg
so by using TSOP1738 , we can attain that , isnt it ?,Often, an IR filter is needed to suppress the stray-light effects.
The receiver using now have ohms range at 0.9M ohms for visible light and its 60 to 180 Ohms in the case of IR radiations, using a higher resistor decreases the range of IR ? I am using 1K and it gets a range of some 5cm onlyI would start with an analog ohmmeter and check how the detector diode responds to IR light from the LED. You will also see if and how much the surrounding light affects the detector diode. Often, an IR filter is needed to suppress the stray-light effects. Your circuits can work also without the PNP or NPN transistors; you can adjust opamp gain for the best results.
I am making an obstacle detector, by making a pulse circuit, the whole circuit becomes huge, because I have to use some 8 such sensor in the projectWhy? What's the limitation imposed for this circuit?
I have to use some 8 such sensor in the project...
Thanks for nice suggestionYou mention coding. A pulsed transmitter can be made with the 10F200 from Microchip plus a small driving mosfet (if needed)(see:PIC10F200 ). It is hard to envision anything much smaller compared to your original plan of using discrete components. The receivers are highly integrated and very small. If you don't want to do the coding of an MCU, transmitters can be made using multivibrators. Working circuits for such have been posted on this forum recently.
The biggest advantage is that the the pulsed systems work well in various lighting conditions. A simple IRED transmitter and phototransistor or other detector will have poor range and be quite susceptible to interference.
Maybe it is time to rethink the requirement for a non-pulsed system.
John
