salem123456
Newbie level 2
hi
mat codes have been done correctly, i would like to know that how to compare those things
here is the question
Consider the example of digital modulation with gray coding . transmit a binary data stream using communication system that consists of a modulator , channel and demodulator ,perform the tasks in the following ,
mat lab code has been done.
then
Repeat this task without applying gray coding to the data stream. Compare the bit error rates of the two tasks
thanks
then
thanks
