cutedrummerboy
Newbie level 6
I found a project of Digital Voltmeter and ammeter in a website but they don't give the source or hex file. can anyone recommended me a good project as provided in this website? Digital Voltmeter Ammeter
I've got some doubt: current shunt is 0.47R 5W resistor and range is supposed to be 10A. quickly calculating power dissipation in the resistor will be I^2*R which in this case is 10*10*0.47=47W. Resistor is rated at 5W. Good luck with that, expect smoke if you want to measure high currents.
You can have upto 16 channels of reading voltage/current or any type of sensor, Not sure about frequency counter never really done anything like that but i would suppose it is possibleneed info about your data logger project
can you add more input for reading voltage and frequency counter?
Here is the calibration settings:
The Voltmeter Ammeter can be easily calibrated by temporarily connecting three (SETUP, UP & DOWN) tactile buttons or even a piece of wire to C1, C2 and C3 PIC16F876 microcontroller ports. But C1, C2, C3 must be held low with a 4K7 resistor
To enter the calibration setup mode make sure the meter is powered off. Press and hold the SETUP button while powering the meter until "Calibration Mode" message is displayed on LCD display. Release the SETUP button
after "Calibration Mode" message disappears this will show “Calibrate Volts” we will be calibrating the voltage readings and real time voltage reading will be displayed on the display. Connect the highest voltage to Input that you will be normally measuring then connect the commercial multimeter to input as well. We will be matching the voltage of PIC voltmeter with the commercial multimeter. Use UP & DOWN buttons to match the voltage on both devices.
Once the voltage is matched and your happy with it press the SETUP button This will then show “Calibrate Amps” we will be calibrating the current readings and real time current reading will be displayed on the display. Lower the voltage on the PSU Connect a load a load from 500MA to 2A in series with your multi-meter to the output of the Pic multi-meter, Again we will be matching the current readings on both meters. Again once your happy with the readings press SETUP button this will the store the calibrated setting in the Non-volatile EEPROM memory and automatically restart the PIC multi-meter. No need for power down. Calibration process now completed. EEPROM memory is retained even if the power supply is disconnected. The calibration process only needs to be performed once. If you ever need to change the calibration settings again you can do so by just following the calibration process again.
Wizpic
This is over 2 years old and your the first person to ask this, I put a time limit in to actually see how many people would build it and use it well spottedThe meter is good .After the calibration works some time.Next show,sCONTACT WIZPIC EDA FORUM. How to get the original version
Wizpic
We are tried many time same with your calibration procedure. after the calibration works normally only 3 minuts,.....lcd show's CONTACT WIZPIC EDA FORUM, This is our last attempt.This is over 2 years old and your the first person to ask this, I put a time limit in to actually see how many people would build it and use it well spotted
What voltage and current range you need and I will see if I've still got the original code and take out the time limit
wizpic
wizpic
