View RSS Feed
Recent Blogs Posts
  1. Android client ThingSpeak extension for MIT Application Inventor 2
    The following attached file contains a ThingSpeak client extension Name:  IconTS.png
Size:  785 Bytes that allows one to easily make use of the Read and Write features of the ThingSpeak cloud service provided by MathWorks in such a manner that programmer is able to transparently make use of the service without having to deal with much details of the implementation in the code side. With the App - also attached - you can easily check the extension working on a friendly interface:
    Categories
    Uncategorized
    Attached Thumbnails Attached Files
  2. Android client SSH extension for MIT Application Inventor 2
    The following attached file contains an SSH Client extension Name:  ssh_hkj_icon.png
Size:  271 Bytes which I made for my own use, but it may also be useful for users of the MIT Application Inventor 2 (AI2) community, or even to the AppyBuilder community (code intrinsically compatible for the last one, but not tested). This is just the current stage of development, but if you want to get updated revisions, you can get the last released source code at Github.
    Categories
    Uncategorized
  3. Working through Annex I.1 of the 802.11 PHY standard in MATLAB
    Note: In earlier versions of the 802.11 standard, the (BCC) OFDM example was given in Annex G. However, an error existed (e.g. in IEEE Std 802.11-2007) in that the FCS was incorrect (see link or search online for "IEEE 802.11-09/0042r0").
    The WiFi (802.11) standards documents are free to download from the IEEE webpages (see, for example, here). (Sadly, you are required to register first, which I would describe as irritating and pointless).
    Updated 31st October 2018 at 08:02 by weetabixharry
    Categories
    Uncategorized
  4. Routine for handling 7-seg display on CCS
    The following function may be useful for those who are starting in the microcontroller's world and wish to implement applications using 7-segment display with the CCS compiler in PIC platform. I've used long time ago:
    void Display7seg ( char value )
       char pin=0 ;
       while ( pin< 8 )
           if ( SEGMENTCHARS[value ] & ( FIRST_SEGMENT >> pin) )
             output_high ( DISPLAY_PINS[pin] ) ;
           else
  5. Programmable Cyclic On-Off Timer with Relay Output
    This project is to build cyclic on-off programmable timer. In this project user can set ON timer and Off time using keys and 7 segment display. Relay is provided as output, where relay will be remained ON for ON time and it will goes OFF after ON time overs. And Relay will remain Off till Off time overs.
    Components required for the project:
    1 x PIC16F876A
    4 x Keys
    4 x 7 Segment
    Here is hex file path:
    https://github.com/embhobbb/electronicsDIY ...
    Categories
    Uncategorized
Page 1 of 69 1 2 3 11 51 ... LastLast
