electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
How to put a bmp on an lcd
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> How to put a bmp on an lcd
Author Message
Dark Angel
Post23 May 2003 21:20
fastlcd
I begin programming in C a graphic LCD 128x64.
I found some programs called bmp2lcd wich change a bmp file into an array, but there is no example of using it.
How do you put this on an graphic lcd.
Does anybody have examples?
Thanks
I'v googled, but only found the programs and NONE of them explained how to use it.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
cancel
Helped: 11
Post24 May 2003 7:50
bmp to lcd
hi .. have a look here:
http://www.geocities.com/dinceraydin/lcd/index.html
lots of usefull infos
regards
cancel
Back to top
ME
Helped: 13
Post24 May 2003 12:37
bmp2lcd
This is a dead link
Back to top
Dark Angel
Post24 May 2003 12:43
bitmap to lcd
Already found this site.
Thanks anyway.
I use a program bmp2lcd wich makes header file from the bitmap wich you include in the c file. The header file contains an array, but i really don't know what to do with it. (i'm not an expert in embedded c).
On mp3 players with graphic displays are for example the buttons defined, but i don't know how this is done.
Sorry, but you need login in to view this attachment
Back to top
DaMa
Post24 May 2003 14:29
lcd bitmap converter
Which type of compiler and microcontroller that you program?
Back to top
Dark Angel
Post24 May 2003 16:03
bmp lcd
At this moment i'm using an atmel 8515 with avr-gcc compiler.
After testing/learning i want to use it with a HC12.
But any example is welcome. Most examples in the net are for the character displays.
Back to top
direnc
Post24 May 2003 17:17
lcd bitmap
http://www.indata.si/grega/ has some AVR GCC code for graphic LCDs based on HD61202 or KS0108. You can usa that as the base of your project.
As for what do do with the header you get.
Enable left controller
Set Page and column address 0 . Sent 64 bytes from the file.
Do all of the above 7 more times, increasing the page address every time. Now you have your image on the display.
I hope this helps.
Back to top
DaMa
Post24 May 2003 20:11
bmptolcd
Toshiba T6963C Dot Matrix LCD Controller example codes in PIC and Intel 8051.
http://ourworld.compuserve.com/homepages/steve_lawther/t6963c.htm
Back to top
DaMa
Post24 May 2003 20:27
bitmap lcd
Program to control a T6963C-based 240x64 pixel LCD display
using the PC's Parallel Port (LPT1:) in bidirectional mode
written in Microsoft Quick C
Back to top
ME
Helped: 13
Post24 May 2003 20:33
graphic lcd bitmap generator
http://www.avrfreaks.com/phorum/read.php?f=3&i=42118&t=42118#42118
Back to top
amtalan
Post27 May 2003 10:18
graphic lcd bitmap
Go to
http://www.ucos-ii.com/
and have a look at uC/GUI, they are a lot of well structured C writen libraries, they can write on an LCD letters, numbers with different fonts and also bitmaps.
A.
Back to top
Dark Angel
Post27 May 2003 23:12
lcd bmp
Thanks for the help.
The files from http://www.indata.si/grega/ really helped me out togeter with the instructions from Direnc.
For now the bmp is working on the total display.
Next thing to learn is how to put a small bitmap on a position on the lcd.
Thanks for the links and help from everybody.
Back to top
ME
Helped: 13
Post28 May 2003 11:25
bitmap converter lcd
Here's an AVR Graphic LCD example written with ImageCraft ICC Compiler: http://pages.infinit.net/hc1x/AVR/GraphLCDLibrary/GraphLCDLibrary.htm
Main page: www.microsyl.com
Back to top
svicent
Helped: 23
Post28 May 2003 17:05
bmp to glcd
Go to www.fastavr.com.
You can download the FastLCD utility.
Regards,
Back to top
ME
Helped: 13
Post28 May 2003 17:13
glcd bitmap picture
Regards,
This is for Basic and not C as he is using.
Back to top
zb7401
Post02 Jun 2003 9:16
bitmap to glcd
TURN HTE BMP TO DAT THAT the lcd can print on! it is 8bit data!see the lcd documentS and Settings!
Back to top
lta2
Post07 Dec 2007 16:24
fastlcd
HI ALL,CAN YOU HELP ME?I HAVE A GLCD 64X128 WITH LABEL SC12864J4 , BUT I DIDN'T SEARCH THE DATASHEET OF IT .WHO HAVE SEND ME PLEASE THANH
Back to top
MrChips
Post31 Dec 2007 14:47
lcd bmp converter
Turn off your caps is shoooooooooouting ,
This post is 4.5yrs old ExclamationExclamationExclamation.
To place bmp on glcd either write your own code basic/c/asm etc etc or find bmp converter.
Neutral
Back to top
super_eng7269
Post01 Jan 2008 21:12
bitmap graphic lcd
thank for all
Back to top
Bernaco
Post16 Jan 2008 15:54
bitmap glcd
Hello to all !
For graphic designs for graphic monochrome LCD Modules up to 240 x 128 pixels, based on bitmap files or jpeg pictures files , please visit bitmap2LCD.com
A freeware beta release of bitmap2LCD will be ready for download at the end of Janaury 2008.
A configurable table of constants is generated in a header file for the C compiler and it offers painting and text writing features.
Best regards
Back to top
crespo
Post19 Jun 2008 11:27
bitmap graphic lcd
hi iam using lcd JHD24064 with controller T6963c
iam want to display a bmp on lcd
pls help
Back to top
Nimish
Helped: 1
Post19 Jun 2008 19:17
fastlcd download
You can put BMP to an LCD using Z_bmp to hex
.Step by step procedure on http://lcdinterfacing.googlepages.com/nokia3310
Back to top
mostafahk
Helped: 2
Post20 Jun 2008 13:29
fastlcd avr gcc
you can use KMW for :
calculate 7seg code.
convert pictures for graphic LCD.
stk200 tester.
and many features.
http://kavirkit.ir/kavirupload/files/10/KMW.zip
http://kavirelectronic.ir/fa/modules.php?name=Forums&file=viewtopic&t=352
i wrote this.please tell me any problem and proposal.
its need .netframework2.
Back to top
nrs8010246
Post08 Nov 2008 14:44
glcd bitmap to hex converter ccs
Regards,
I tried FastLCD and LCD Assistant. All i am getting out of the bitmap is an array full of zeroes. what could be the problem ?
Back to top
Bernaco
Post06 Feb 2009 16:15
bitmap for lcd
You can also try the latest release of bitmap2LCD freeware
Browse to the download section of the http://bitmap2LCD.com website.
Back to top
Nimish
Helped: 1
Post05 Nov 2009 5:40
Re: fastlcd download
new link is http://www.lcdinterfacing.info/Nokia-3310-LCD-Interface.php
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
How to put my LCD to blink? (2)
How can we display a BMP file on CSTN LCD by 8051? (1)
How do show the bmp format at the lcd ? (2)
bmp to graphic lcd hex converter (4)
displaying BMP file in color graphic lcd (1)
bmp to hex tool for ks0108 graphic lcd (1)
how scan and BMP to PCB ? (13)
How to convert bmp in pcb design (3)
How can convert Protel Schematic format to bmp (5)
[Q]How to get RGB data from .bmp file?? (2)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
