| Author |
Message |
ze_dib
18 Feb 2003 13:33 fpga oscilloscope |
Hi
I 'm studying possibilities to make a digital oscilloscope for PC, with onboard RAM to memorize samples.
I have several questions :
=> Wich bus is the easier to use (hard and driver for linux/windows) : PCI, USB or IEEE1394
=> I though about using many low speed ADC (cheapier) to reach sampling frequency I 'd like to use, is it a good way to do this.
Which FPGA would be the most suitable for that project SpartanII, or APEX20k
TOTO2001
| Back to top |
ee_freak
Joined: 28 May 2001 Posts: 28 Location: somewhere in time
18 Feb 2003 14:48 usb oscilloscope project |
| Try www.bitscope.com . They use PIC with CPLD.
| Back to top |
MADURAN
Joined: 01 Jan 1970 Posts: 66 Helped: 2 Location: Romania
18 Feb 2003 14:56 avr scope |
| http://www.chocbar.demon.co.uk/
| Back to top |
ze_dib
18 Feb 2003 15:08 oscilloscope project |
Thank a lot for those usefull Links
I think the second one is near of what i'd like to design.
I'd rather use PC SDRAM memory to allow storage of samples, cheap solution with a FPGA.
Toto2001
| Back to top |
dsp_
Joined: 02 Mar 2002 Posts: 66 Helped: 3 Location: right here ... right now ...
18 Feb 2003 15:38 digital oscilloscope schematic |
hi toto
look for "time interleaved sampling" or "interleaved sampling adc" on google
theres an app note on this subject on the maxim homepage
http://www.maxim-ic.com/appnotes.cfm/appnote_number/384
but maybe this is not the best approach for hobby purposes
| Maxim wrote: |
| Unfortunately, this approach is complex and entails extra cost, a lengthy calibration, and mathematical analysis. |
HTH
dsp_
| Back to top |
ze_dib
18 Feb 2003 17:25 digital oscilloscope project |
Thank for the application note.
It's almost what I was thinking about.
Could a FPGA assume the clock for ADC sampling, I mean do you think the jitter on Clock signal would be acceptable for such a thing
Thank for the anwers
| Back to top |
hugo
Joined: 01 Jan 1970 Posts: 286 Helped: 27 Location: canada
19 Feb 2003 2:36 jyetech oscilloscope |
This link could be useful :
http://www.mccord.plus.com/FYP/final_report.htm
(Implementation of a low-cost PC based quad channel real-time / storage oscilloscope).
| Back to top |
ze_dib
19 Feb 2003 14:38 pc oscilloscope schematic |
In fact, I'not really looking for a low cost oscilloscope,
It' rather a high speed oscilloscope at lower cost, based on FPGA in order to allows configurable sampling and filtering frequency, configurable sample width and number of samples. I'm particularly intrested in the possibility to make hardware digital processing before storage.
I also plan to use PC memory to lower the cost of data storage.
I don't which High speed pc bus (PCI, USB and firewire) is the easist to implement (with a chip or in fpga) and the cheapier.
Here it is
Toto2001
| Back to top |
Gunship
21 Feb 2003 18:57 oscilloscope schematic |
| toto2001 wrote: |
Here it is
Toto2001 |
For PCI, you usually buy a chip for the interface or a core and put into the FPGA. It will probably give you the fastest transfer of data between the scope portion of the FPGA and the PC. But doing a good high speed PCI can be difficult. Also, the design is not portable. (You need to move the entire PC around.)
USB is good especially with USB 2.0. It is very good speed. You can purchase a USB chip that can come with all the driver development tool you need. The design is also portable. If you need to move the scope around to another lab, this is a better choice.
I don't know too much about Firewire except used it on a few occassion. Mainly for Digital Video stuff. I will not recommended this interface for scope. I don't think it is ever used for instrumentation purpose.
Anyway, just my 2 cents. Hope that help.
Gunship
| Back to top |
DrShoe
24 Feb 2003 22:36 usb oscilloscope schematic |
The AD9283BRS-100 is a AD converter in the $6 range, free samples.
8-Bit, 50 MSPS/80 MSPS/100 MSPS ADC
| Back to top |
ze_dib
25 Feb 2003 12:51 oscilloscope projects |
Thank for all those usefull advice.
I had now a better view of what will be the project.
In my firts mind, I was looking for PCI, but the mobility is an argument I didn't think about.
The USB 2/1.1 seem a beter choice in the sense that it allow to be plug on a PC, a mac...
It will just take a little longer to set the filters parameter and to back up all the data to the computer, but it may be easier to do too !!!
If people are interested in taking part in it, they 're welcome
TOTO2001
| Back to top |
mbyka
01 Mar 2003 15:28 pc oscilloscope project |
http://alternatezone.com/electronics/dsoamk3.htm
ISSUE 97
August 1998
Theme: DEBUGGING TECHNIQUES
Task Manager—Almost Made 100, Ken Davidson, 2.
Reader I/O, 6.
New Product News, 8.
Bitscope—A Mixed-Signal Capture Engine, by Norman Jackson, 12.
http://www.circuitcellar.com/library/toc.asp
| Back to top |
mbyka
01 Mar 2003 22:43 oscilloscope adc |
http://www.vitrum.cz/snail/bitscope.htm
http://www.vitrum.cz/snail/products.htm#BITSCOPE
or ftp.circuitcellar.com 21 Anonyymoue \ftp.circuitcellar.com\Circuit_Cellar\1988\Issue_5
ftp.circuitcellar.com\Circuit_Cellar\1992\Issue_25
ftp.circuitcellar.com\Circuit_Cellar\1998\Issue_97
| Back to top |
Goliath
23 Mar 2003 16:46 oscilloscope fpga |
You could also have a look at the following link
http://www.johann-glaser.at/projects/DSO/
Goliath
| Back to top |
RF_Router
23 Mar 2003 18:16 oscilloscope front end |
I think that the bus of your chose should be mainly decided by your sampling rate. What is the maximum rate that you would like to sample? And you can go from there? Just bar in mind that your sampling rate should be at least 2.5 times more and also you should make sure that your sampling don't vary. You wouldn't want to be involved in a varying sampling system cause it is too complicated to handle so usually if you want to make sure that, then you might want to have some sort of a buffer mechanism between your PC and your board.
Enjoy,
RF_Router
| Back to top |
Sobakava
27 Mar 2003 8:02 dso schematic |
If you don't need deep memory, just generate two video rams
to store pal or ntsc image and fill this memory with the graphic
that you want to display. (scope graph) and generate standart
video signal with this data. It is useful if you don't want to use
a computer with your oscilloscope....
| Back to top |
Google AdSense
27 Mar 2003 8:02 Ads |
| Back to top |
qinqiuer
31 Mar 2003 16:05 oscilloscope input stage |
| Goliath wrote: |
Goliath |
this plan is best one !!!
because it has a good solution in analog front-end!
and i think the usb is a good choice, but is complex
| Back to top |
ME
31 Mar 2003 20:38 pc oscilloscope circuit |
There is an error in this schematic: http://www.johann-glaser.at/projects/DSO/schematic/MainSchematic.png
IIC pull up resistors at SDA and SCL should be connected to 3.3V and not 5V as shown in the lower left corner of the schematic. Both AN2131
and EEPROM is 3.3V types.
| Back to top |
Make_Pic
13 Jun 2003 20:25 eoscope |
| Quote: |
Goliath |
This link has not the sources for FPGA!?
| Back to top |
joilen
15 Jun 2003 14:14 firewire oscilloscope |
also check out www.fpga4fun.com, this guy has made a dso using a fpga, he's currently doing a tutorial on how he did it along with all the verilog code...
A
| Back to top |
Make_Pic
15 Jun 2003 15:02 project oscilloscope |
joilen: It is good information for me, but
I need any information about a stroboscopic method of the measurement for DSO!
| Back to top |
Make_Pic
15 Jun 2003 15:06 cpld oscilloscope |
I need any information about a stroboscopic method of the measurement for DSO! The stroboscopic method allows to measure Frequencies up to about 3 GHz.
| Back to top |
xgnetto
| Back to top |
Sobakava
13 Oct 2003 11:29 dso project |
" I need ideas about 'triggering' "
My design will be based on a simple
FPGA/CPLD or a fast Scenix SX + FIFOs.
If I don't need to implement "pre-triggering", I suppose I don't have to store samples all the time. Only a trigger signal from analog channel or external trigger channel is required to start acquisition of "n" samples with sampling rate
of "m" MPSP.
After filling FIFO, I'll start USB2.0 transfer with
CY7C68013 (Cypress EZ-USB2+8051 IC)
I want to know about triggering circuit. How can I do that in analog way?
I need to generate a pulse from specified level and specified edge (hi-to-lo or lo-to-hi) of the analog signal and then I'll set a flip-flop, and reset this flip flop after FIFO filled so I wont get repeatedly pulses for every matched level-edge during sampling.
For setting trigger level, I am thinking about using a DAC/digital potentiometer. Or If I do this after ADC, I can use 8 bit magnitude comparators...
May be I'm in wrong way. What do you think/recommend?
| Back to top |
Aoxomox
15 Oct 2003 21:51 digital storage oscilloscope project |
If you don't want to pre trigger by storing samples in a circular buffer, why don't you implement a digital compare for the sampled AD value.
If you want to detect e.g. low to high transition you have first to wait that the AD input value becomes smaller than the trigger level. then you can reset your trigger pulse. the next time the ad value becomes equal or higher than this level you can set the trigger pulse.
the advantage of this way is you can implement a triggering unit without any additional analog hardware which can drift by temperature ans so on.
another advantage is you can implement schmitt triggering behaviour when having two independant levels for upper and lower AD value. To implement this with analoge matters you will have to build up two DACs or else.
Hope it helps,
aOxOmOx
| Back to top |
phongwiroon
08 Dec 2003 6:37 build digital oscilloscope |
| try to use gameboy for small oscilloscope
| Back to top |
Aoxomox
25 Dec 2003 21:21 jyetech.com |
Has anyone schematic or principle of an oscilloscope input section??
mainly with the following requeirements:
- high BW
- high impedance
- low distortion
- low noise / high sensitivity
Any suggestions for a good HF input attenuator circuit??
Any help is appreciated.
| Back to top |
martingn
13 Apr 2004 14:11 usb scope project |
Hi people,
Could anybody go forward and build something?
Any interesting to share ??
Regards,
MArtin
| Back to top |
Cluricaun
08 May 2004 17:50 usb oscilloscope schematics |
Hi
I have a bitscope since a couple of years, and now I like to make a update to the communication between PC and bitscope. They (Bitscope) sell a ethernet-RS232 and one highspeed USB-RS232 adapter. I think they are a bit to expencive to order, must add custom tax and VAT. So I wonder if there are any projects I can use to get either a USB or Ethernet adapter, PIC code or sch.
More info here:
www.bitscope.net/store/?p=view&i=item+0
www.bitscope.net/store/?p=view&i=item+1
Thanks in advance for any help
Cl
| Back to top |
joc_06
25 May 2004 12:56 oscilloscope chip |
| martingn wrote: |
Hi people,
Regards,
MArtin |
I am starting building a project similiar to the ldso next week. Just waiting on parts at the moment, i will keep you updated here
| Back to top |
