electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Measurement of RPM's of Dc Motor
Post new topic  Reply to topic    EDAboard.com Forum Index -> Electronic Elementary Questions -> Measurement of RPM's of Dc Motor
Author Message
zeshan
Post07 Nov 2009 17:09
how can i exactly measure the RPM's of a fast DC motor (15000 RPM)????????are such motors available in Markets?plz guide me
Back to top
hameeds01
Helped: 15
Post07 Nov 2009 17:15
Re: Measurement of RPM's of Dc Motor
via infrared sensor
http://www.edaboard.com/ftopic370126.html
Back to top
zeshan
Post07 Nov 2009 17:26
thanx.but are not these Expensive????? I M A STUDENT and want toimplement for my project
Back to top
haker_fox
Helped: 4
Post08 Nov 2009 15:06
If only need to measure the RPM take any open optocoupler and slotted disk. So you wiil be able to do that! If you also want to measure angular position you should be ready to spent much of money. Encoders for high speed are very expensive.
Back to top
zeshan
Post08 Nov 2009 16:08
how much money? what about the availablity of such motors?????? plz guide
Back to top
ark5230
Helped: 15
Post08 Nov 2009 18:34
Here is a link for 15000 RPM motor, you can find further details
http://www.brocott.co.uk/electric-motors/micro-motors/micro-motor-pcd-mountable-15000-rpm-15-45v-p-543.html?osCsid=61vopoc60srkdc6u8k477c1rgh6idq0t
Raoof
Back to top
haker_fox
Helped: 4
Post09 Nov 2009 1:20
Quiet!Very Happy As I told you if you only need to measure the angular velocity you shouldn't worry about the cost.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
hameeds01
Helped: 15
Post09 Nov 2009 7:13
u can get these optical sensors free
just find an old Ball mouse thatz it
Back to top
pranam77
Helped: 94
Post09 Nov 2009 8:31
When you say you need to measure the speed up to 15000 RPM, the circuit or the sensor too shud be fast enough to process and display the same. Thus if you are calculative with the component cost, so will be the results. Cheers.
Back to top
zeshan
Post09 Nov 2009 10:29
can optocoupler help us measuring upto 15000 RPM????????? Acurately
Back to top
betwixt
Helped: 64
Post09 Nov 2009 10:41
Yes, all you need is an opto-coupler, or more accurately an opto switch.
You need access to something rotating on the motor, it could just be a point on the motor shaft but it gets easier if you can use something with a larger diameter. All you have to do is use a reflective opto switch and place it close to the moving part. Make a section of the moving part reflective and part of it non-reflective. The light from the opto switch shines on the part and whether or not it sees a reflection depends on the rotational angle (reflective or non-reflective section is in front of the switch). all you have to do then is count the frequency of the reflections, you get one per revolution so it is easy to measure.
If you can access a disk rotating on the shaft you can do the same thing by passing or blocking light through it and using a slotted opto switch instead.
I would be cautious about using a ball mouse opto system, with typically 100 holes in the wheel and at 15,000 RPM the pulses would be very fast, possibly 25KHz or more so counting might be more difficult.
Brian.
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
motor speed measurement (3)
DC Motor control using PIC16F877 & L298 (Motor driver) (14)
2 motor circuit, the main motor will be going forward (4)
difference between servo motor and 3-phase synchronous motor (4)
Difference b/w Simple DC motor and Brushless DC motor (5)
motor driver/motor controller (9)
Spindle motor == servo motor??? (2)
Stepping motor,How can I identify a kind of stepping motor? (5)
NF measurement (18)
TV Rating Measurement (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
